trying to build pedometer with serial monitor as display
  • Thread starter Deleted member 750607
  • Start date
Joined Dec 31, 1969
Using arduino uno, getting error message, seems to be a syntactic error...???
had a couple other drafts, in one I was able to read on my serial monitor "1" for still accelerometer and "11" for moving accelerometer
in another, I was able to read nothing for still accelerometer, and "1" for moving accelerometer
this draft won't compile successfully
I would like it to start at 0 on serial monitor, and increase by one each time accelerometer moves on any of 3 axis
Help is appreciated, go easy on me, im a beginner
this is my code - error message: expected ')' before 'x'
C:
const int xpin = A0;
const int ypin = A1;
const int zpin = A2;
int Steps = 0;
int x = 1;
void setup()
pinMode (xpin, INPUT);
pinMode (ypin, INPUT);
pinMode (zpin, INPUT);
Serial.begin (9600);
void loop()
int a = analogRead (xpin);
delay (500);
int b = analogRead (ypin);
delay (500);
int c = analogRead (zpin);
delay (500);
if (a < 678)
    Serial.print (Steps ++x);
if (b <= 464 )
if (c <=4 )
if (a >= 680)
if (b >= 674)
if (c > 6)
Moderators note : used code tags
djsfantasi
Joined Apr 11, 2010
9,237
What is the variable Steps used for? You define it and never change it.
I have a thought that you may want to display the word Steps on the display... Is that the case? Then, you don’t need a variable. Just refer to it by a character constant.
Serial.println( “Steps “, ++x);​
Joined Dec 31, 1969
thanks to all of you. I've got it working how I want now, with this code
int Steps = 0;
void setup()
void loop()
int x = analogRead (xpin);
delay (500);
int y = analogRead (ypin);
delay (500);
int z = analogRead (zpin);
delay (500);
if (z <= 4)
Serial.println (Steps++);
