Triggering input of a Flip-Flop
Yami
Joined Jan 18, 2016
354
I've got this question-what is the the triggering input of a Flip-Flop is called?
Would it be "enable"
Yami
Joined Jan 18, 2016
354
It depends on your application but in logic applications its enabled.
Cool thanks, also I'm stuck on this question too. "Show how a negative edge triggered D Flip-Flop can be formed using S-R Flip-Flop?"
Any idea?
Appreciate the help
33,003
Depends on who is choosing the terms because there is no rigid, universally accepted terminology.
If the trigger input is edge-sensitive it is often called a "clock" while if it is level-sensitive it is often called either a "write enable" or a "write strobe" (sometimes shortened to just "enable" or "strobe").
33,003
Any idea?
Appreciate the help
There are a few ways to do this depending on if you want the output to appear immediately after the negative-going edge or if you want the output to appear on the following rising edge.
