Triggering an led when power is turned off
SanctuCaryCustoms
Joined Jul 4, 2019
7
Hello everyone,
I’m trying to make a 12v circuit that turns on a led when the 12v feed to it is lost. Led only has to stay on for a couple of seconds and will need to turn off again as soon as the power returns. Also needs to be as small as possible.
Thanks in advance
iimagine
Joined Dec 20, 2010
512
I'm not sure if this is the most efficient way and small enough, but it does the job. You will have to calculate the timing RC that suit your need.
38,747
Below is the LTspice simulation of another circuit that performs the desired function.
When the power is turned off (blue trace), it generates a nearly constant current (yellow trace) as the capacitor discharges (red trace), so the LED brightness stays essentially steady until the cap is nearly discharged.
The LED stays on for over 2 seconds after the power is shut off, for the capacitor value shown.
The LED current is about 1.7mA nominal, as determined by the value of R2, but that should be sufficient for a high efficiency LED to be readily seen.
Higher LED current will, of course, shorten the LED on-time for a given capacitor size.
If space is at a premium, you can save a package by using a dual 2N3904 transistor such as the MBT3904DW1.
LesJones
Joined Jan 8, 2017
4,538
Hi MrChips,
If the original load (Before switch off.) does not pull down the input to you circuit you would need a pull down resistor on it's input. Other than that I can't see any reason why it should not work.
Les.
38,747
Below is the LTspice simulation of MrC's circuit:
The tradeoff is the drop-off in LED brightness for this simple circuit versus the constant brightness for the more complex circuit.
iimagine
Joined Dec 20, 2010
512
This circuit is very efficient, it only consume 12uA which is practically nothing:
This circuit uses least components but consume 120uA:
Edit: I was posting this almost at the same time as crutshow. Our circuits look similar lol
Edit: Dont even need the 470 resistor for the second circuit if the transistor's HFE is below 250
35,096
Yes, you are both right, @LesJones and @iimagine.
Add a 1MΩ pulldown resistor from base to collector. (I don't do simulations. I do real breadboarding.)
Change LED to high efficiency blue for longer LED visibly on.
Also, change capacitor from 100μF to 220μF for about 10 seconds of LED being visible.
