Tricks and tips Y2024
Status
Not open for further replies.
Wendy
Joined Mar 24, 2008
23,869
This is the sixth thread with this name I have indexed the first 2 in my personal index, Wendy's Index . To keep it from being closed prematurely, I am setting the following rules:
1. Do not comment just for the sake of posting. Only posts containing a trick or tip will be allowed. This thread will be heavily moderated, anything posted here that do not meet this criteria in the opinion of the moderators will be deleted. If you have a question start your own thread. If you really like the idea use the "like" tag (button).
2. Any repeats of someone else's ideas from this or the previous tricks and tips threads will also be deleted.
3. At the end of this year This thread will be locked and a new one started next year.
Be aware of my comment about being heavily moderated. This thread is not meant to be a dumping ground as has happened in the past.
Electronic Tricks and Tips Y2008
Electronic Tricks and Tips Y2012
Electronic Tricks and Tips Y2022
Electronic Tricks and tips Y2023
35,299
When you have a standard self tapping screw that has ripped out from the hole, the common practice is to fill the hole with a wooden matchstick or dowel before reinserting the screw.
A quick repair is to fill the hole with cotton wool and soak the cotton wool with super glue (cyanoacrylate). The super glue reacts with the cotton wool and hardens almost instantly. The hole is now ready to take the self tapping screw.
35,299
The small 315mA fuse on a DMM (digital multimeter) is often blown because the meter leads were applied across a voltage source while the meter was set in current measurement range.
In order to correctly measure current with the DMM, the circuit must be broken and the meter must be placed in series to bridge the break in the circuit.
To avoid blowing the fuse, avoid using the current measurement range. Instead, set the meter to measure voltage and measure the voltage across a resistor already in the circuit. If there is no resistor present, break the circuit and insert your own resistor (called a shunt resistor). The value of the shunt resistor should be lower than 1/10 the total (or net) resistance of the circuit.
Use Ohm's Law to calculate the loop current:
I = V / R
35,299
Getting your oscilloscope inputs mixed up?
Can't tell which probe is CH1 or CH2?
Get the missus' bright nail polish and paint a small ring around the cable at both ends of the probe cable.
(For those of us who don't have the coloured rings now shipped with new probes that match the colour of the scope trace.)
Ian0
Joined Aug 7, 2020
13,317
Maybe you will never need to use a NXP SC16IS740 standalone UART on any of its relatives, but if you do, note that there is no internal pullup on RESET.
cmartinez
Joined Jan 17, 2007
8,890
I normally put a drop of Gorilla Glue (polyurethane) in the hole and the screw, and then lightly insert the screw. The glue will expand and take the shape of both the screw's thread and the hole, and will hold well enough for the screw to be removed and re-tightened a few times.
Status
