Treadmill "Kettler Toronto" (board M3800 TCS-3) IGBT Blows at startup (solved)
João Ferreira_1534275331
Joined Aug 14, 2018
11
Hi there!
I was searching for some information about this particular module M3800 TCS-3.
So, problem is:
Fist time this treadmill fail's I notice that, wen we switch it on, the tread motor simply starts by him self, and 1 sec after, the encoder detect's that the motor was spinning without permission and stop it, opening a safety relay. This time I simply replace the IGBT that was shorted and changed the IGBT Driver too just to get shore...
After tested for about 1/2 hour everything works just fine..
(One days after... lol...)
Now, I was plugging it and the IGBT blows up right away ...
I simply redo the same process (new IGBT and IGBT Driver) and let it work for 1/2 hour... every thing looks too good to be true so I star plugging and unplug-it every 5 sec... and at the 4th try BOOMM, one more blown IGBT.
So, conclusion:
Something is spiking my IGBT at the startup and I didn't imagine what (I've tested every single filtering cap... allOK), have anyone every experienced something like that??? Any clue about what may be the cause?
Thank you very much
(Sorry for my English mistakes, my native language is Portuguese)
MaxHeadRoom
Joined Jul 18, 2013
30,890
Have you tried with a load such as a incandescent lamp to see if it hangs in, also give the motor a test on a DC power supply, automotive battery etc.
Max.
Joined Aug 14, 2018
11
I went to a motor rebuild guy to test the motor. He basically connected it to a dc power supply and run it from 0 to 220V and observe about sparks on the commutator... and it runs fine!
About testing the circuit using a resistive load such as a incandescent light I can try it, but true is, that wen I install a new IGBT I believe it will run fine... the probem is at the start up!
I observe that wen I plug the treadmill to the wall in normal condition the circuit injects current on the motor for an instant ( I belive it is some kind os test function ...) and my IGBT goes out on this instant .... if I plug it and nothing happens I can do start,and the motor will run fine....
Thank you very much
MaxHeadRoom
Joined Jul 18, 2013
30,890
The instant motor power at switch on could be the problem and possibly not normal, you could still try the lamp test to see what is happening.
Max.
Joined Aug 14, 2018
11
I've conected a 250w lamp but once i didn't received new IGBT's yet to replace, there is not much to see... any way I searched for spikes using the "Max" function on my multimeter and I didn't found much.
Thank you very much Max for your kind help!
To test with the lamp I will need a new IGBT ... and I will change the series diode too ...just in case...
(For now, I will wait for the new components. Soon I will give more news)
Joined Aug 14, 2018
11
Hi! Just back today from small holidays and notice I didn't received the igbt's yet.
Any way I connected the motor to a DC power supply (max 30VDC-5A) to see what happens and looks nice...
Next I pick up a chinese dimmer and a rectify diode bridge, and tested again... Like in the picture below...
In this assembly the motor gets sparky on the brushes... I'm not shore if is because of the dimmer quality (Chinese cheap stuff :) ) or if is really a motor problem... But I do believe more, that is a dimmer fault, once I saw the "Motor rebuilding Guy" testing it with an old school dimmer and works fine...
Any thoughts ?
Thank you
Joined Aug 14, 2018
11
REVIEW LAST POST--> The sparks was caused by excessive voltage on the motor (+-300vdc). On first start using the circuit above, the Dimmer's Triac (BT16A --16Amps) get shorted so it was running on full speed...
This is freaking me out... I add a 10A fuse on AC Side and it blows up on every start... so I no long shore if the motor is OK... any Idea?
MaxHeadRoom
Joined Jul 18, 2013
30,890
If you applied full/high voltage to the motor and it had the flywheel on, that is virtually a dead short until the motor gains any kind of rpm. No wonder the com was 'sparking'.
Test the motor on an automotive battery, it should show any problems at this voltage also.
Any higher voltage than this requires a soft start.
Max.
Joined Aug 14, 2018
11
Hey Max!
The video above, show me running the motor on my 0 to 30v (5A) power supply, I suppose this would be the same to connect it on a car battery, once the motor just drain 1.7A at 12V. Am I right, or missing something? ;)
MaxHeadRoom
Joined Jul 18, 2013
30,890
Hey Max!
I have tested treadmill motors with a gradually increasing DC from 0v to the normal operating voltage and if done slowly the initial current stays exactly the same throughout the rpm range, due to BEMF, this is T.M. motors with no flywheel attached.
The current is relatively low when ran off load.
Max.
Okay. Just wanted to see if the power devices were properly isolated from the heatsink. Not this case, but once I faced a similar case with a treadmill where every time I connected my board, the fuse blowed up. The problem was the IGBT making direct contact with the heatsink.
Joined Aug 14, 2018
11
My two cents: Try with the lamp as Max suggested.
I'received the components yesterday... I've soldered a new igbt and the diode and tested with a lamp... it's starting fine,PWM is OK!
The strangest for me is the fact that the fuse has never blown... strange....
After connect the motor it's running OK too.... I've connected and disconnected the main power several times and all seems OK too.... (notice that the circuit board is lived on a carton board (not properly grownded and heat sinks are off too) ... as soon as I properly assemble the board I will live new details!
Thank you for your kind help
Casually, right now I'm facing a kind of similar problem with a treadmill. When I press Start Button, a power relay is activated giving the bus voltage to the motor. The problem is that just when I press Start Button, the motor goes suddenly at full speed and then blows up my fuse. Fortunately, the IGBTs are okay. I tried with the lamp, and the effect can be appreciated, the lamp is suddenly fully iluminated at startup. Haven't found the solution yet.
Joined Aug 14, 2018
11
So... after struggling a lot.... I figure out whats happening with this treadmill. It was the "A 4503" that is a photo-coupler shutting signal to output without having any input. After remove and re solder the component the problem simply pass!
Conclusion: The photo-coupler wasn't properly grounded due to bad soldering pads and this makes him shoot without
permission. Once the motor receive 230vdc without pulse the current increase dramatically, causing the IGBT failure!
Thank you all for your help!
