Treadmill keeps tripping breaker when motor is connected
Shalsey
Joined Jul 19, 2024
Hi guys, I'm hoping someone could shed some light before I bite the bullet and buy a new circuit board.
I have a Proform premier 900 treadmill, with a 3hp motor and a MC2100ELS 18W-2Y controller. Everything looks to be connected correctly, all earth's are tight etc.
As soon as I switch it on, the motor fires for a second then the breaker on the house trips (it worked perfectly for a long time, this is a recent fault). If I disconnect the power to the motor, the screen on the treadmill lights up and works, however the red LED on the control board does not light up. I removed the motor and bench tested that on a 12V battery, and that seemed to work fine. I connected the motor back to the treadmill but removed the belt so there was nothing dragging it down, and that tripped the breaker. I also tried disconnecting the plug to the treadmill screen/controls, but the motor will still fire then trip.
I'm quite handy but I'm in no way an expert when it comes to diagnostics, is anybody able to shed some light on this please? Much appreciated!
MaxHeadRoom
Joined Jul 18, 2013
30,857
It looks as though one of the semiconductors for for the motor mounted on the HS is defective.
It is best to trouble shoot the MC2100 on the bench , you do however require a 20hz signal to achieve any motormovement.
panic mode
Joined Oct 10, 2011
5,306
tripping fuse/breaker tells you that current is too large. motor may be cooked. once the insulation is degraded you will have higher current draw.
MaxHeadRoom
Joined Jul 18, 2013
30,857
@Shalsey Do you have the reverse-engineered print for these boards?
There is one here if you search, covers most versions, in principle.
Replace the motor with a 100w lamp, temporarily.
