Sorry john. My mistake. it was a 2 kΩ. I double checked the board that I had.That certainly makes sense, based on the voltage ratings of the capacitors. The one I can see looks like it's 400 WV. So, 200 V across a 200 Ω, 0.5 W resistor would blow it in a hurry. I would just replace the diode too. They are cheap and readily available; although, it does not look damaged. With the resistor out of the circuit, EdgeHawk could simply test it too.
John
Right u are....Pardon my barging in, but how would you check for shorts? There must be several ways...right?
And.........Right u are....
It's a tech thing.
