Hi guys
This is a Schematic of a transmission line, using Matlab.
The model I'm working on is a three phase.
I've run a number of fault simulations on the model, in particular a - single line to ground fault. The current surges along the fault point and the voltage sags. This is perhaps normal for that type of fault.
However when T1 and T2 is set to Y/Delta and T3 is set to Delta/Y - there seems to be no fault on the line at least that's the way my analysis is looking. I've double checked my results and parameters and they look fine.
Perhaps this is what I was meant to discover, in fact I think it was.
What I'd like to do is have a chat about this. I'd like you guys if possible to correct any incorrect terminology I'm using and if possible, hopefully we can at some point, reach some type of revelation with this. Though hopefully not too long away... pressures on.
