Transmission lines problem
salhi
Joined Nov 29, 2023
86
Let a star three-phase balanced circuit with line voltage of 230 V, and load \( Z = 16 + 12j \) Calculate the line currents:
so we have this circuit : 1702491763320.png
Considering \( V_a \) to be the origin of phase-voltage so \( V_{ab} \)
We have : \( V_{ab} = V_a \sqrt{3} (30°) \\
V_{bc} = V_b \sqrt{3} (-90°) \\
V_{ca} = V_c \sqrt{3} (150°)\)
and we have \( I_a = \frac{V_a}{|Z|} (-arg(Z)) \\
I_b = \frac{V_b}{|Z|} (-arg(Z)) \\
I_c = \frac{V_c}{|Z|} (-arg(Z)) \)
Thus:
\( I_a = \frac{V_{ab}}{\sqrt{3}|Z|} (-30-arg(Z)) \\
I_b = \frac{V_{bc}}{|Z|} (90-arg(Z)) \\
I_c = \frac{V_{ca}}{|Z|} (-150-arg(Z)) \)
with \( V_{ab} = 230 V = V_{bc} = V_{ca} \)
MrAl
Joined Jun 17, 2014
13,888
so we have this circuit : View attachment 309940
Thus:
What is it you are having a problem with; do you not know how to calculate the numerical values of the currents from the given information?
salhi
Joined Nov 29, 2023
86
no i just someone to verify my solution thats it, because i had been told to post my solution and eventually someone will answer if its valid or not, infinite thanks !
MrAl
Joined Jun 17, 2014
13,888
Oh ok, so you mean the other text there was your own text as those are your results. It looks almost correct so far.
Then I have to ask, why is your solution for 'Ia' so different from the other two 'Ib' and 'Ic'?
Why does 'Ia' have a sqrt(3) in it when the others do not, or stated another way, why do the other two have no sqrt(3) while the first 'Ia' does?
salhi
Joined Nov 29, 2023
86
ah yes my bad they all need to have that sqrt(3) in the denominator coming from the line voltage right?
MrAl
Joined Jun 17, 2014
13,888
Yes going from line-to-line voltage to line voltage you have to divide by sqrt(3), and that goes for any of the phases.
You might take solace in the fact that a balanced three phase system is the simplest and easiest to analyze.
