I am trying to model transmission line parameters (R, L, G, and C) by using its electrical parameters, those parameters are frequency-dependent.
I want to build an electric circuit consist of Voltage Source in series with R and L, in parallel with G and C.
The amplitude of the Voltage source is constant, 1 V, but its frequency varies from (1 to 1000) Hz. I also have variable values for the parameters R, L, G, and C for each single frequency, as a single point. In Excel sheet.
I thank you so much, for your kind assistance and cooperation.
