Hello
I come through this tutorial about transmission lines
The idea is to put two transmission lines with resistive load
-first TL = 50 ohm,
- Second TL = 70.71 ohm
- the load is 100 ohm
The output is like this
When I played with these setting, I found that there is a problem if I put the second TL = 50 ohm, the output is like noise !! Why?
is there a basic document about that theory?
Thanks
-first TL = 50 ohm,
Thanks
