I saw this in a video about audio sampling in arduino, and he put this after the DAC, imagine the AC source as the output of the R-2R ladder. The output is the emitter. He was talking about loudness, saying this would amplify the signal, which didn't make much sense to me. Then I thought it would be to 'follow the voltage' without screwing it up, but it's an open circuit between the base and the emitter. Is there current flowing between the collector and the emitter? Can someone explain to me what this is doing, thanks.
Just a 'side question', in an amplifier montage what is the voltage drop between the collector and the emitter? Since the voltage at the collector is base's amplified and inverted, and at the collector it's base's -0.7.
