Transistor vs Relay
Goerijoe
Joined Mar 25, 2018
5
Hi I have a project that will be necessary to turn 1.5 volts into 6 volts to power a 6v electric actuator. The actuator amperage consumption is unknown but will be minimal (it has a small gear reduction motor) I was initially thinking about using a relay but it's been hard to find a 1.5v relay. Can I use a transistor instead of a relay? How would I go about doing this? Thanks.
AlbertHall
Joined Jun 4, 2014
12,653
Certainly you can use a transistor to switch 6V power to the motor using a 1.5V signal for control. Something like shown below, the transistor type and resistor value depending on how much current the motor needs. The motor should have a reverse diode across it to protect the transistor, anode to the transistor collector.
ericgibbs
Joined Jan 29, 2010
21,586
hi G,
It is as the circuit in post #3, no special name.
Low side driver, means the load is in the collector to supply, you must add a suppression diode across the motor in order to protect the transistor when switching an inductive load.
E
BobaMosfet
Joined Jul 1, 2009
2,211
don't foget the snubber diode around the motor to protect the Transistor
dl324
Joined Mar 30, 2015
18,476
What do you call this type of circuit with transistor directly switching on the motor circuit?
There's no special name. It's just a transistor being used as a switch.
In the example given, the motor is being driven low side. With a PNP, you'd drive the motor high side. In an H bridge, you'd use pairs of NPN and PNP transistors:
