Transistor Latch with Trigger On Low Pulse
jerseyguy1996
Joined Feb 2, 2008
214
I've found plenty of examples of transistor latch circuits that trigger on a positive pulse but I couldn't find one that will trigger on a negative pulse. Is it as simple as inverting the output of the NPN transistor to hold the PNP transistor on as I've done in the attached schematic?
38,819
I want the On button to turn power on as well as provide a low pulse on the trigger pin of a 555 timer.
Then you need a negative going pulse, not a negative polarity pulse.
If both circuits are operating from the same supply voltage, just connect the 555 trigger pin to the top of the ON pushbutton.
jerseyguy1996
Joined Feb 2, 2008
214
Thanks...that was the plan and why I wanted my latch to operate on a low pulse. Basically it turns on and triggers the 555 all from one button. A second button turns everything back off and there shouldn't be any current consumed in the off state besides whatever leaks across the transistor junctions. I just couldn't find an example online of a transistor latch circuit operating on a low pulse....only a high pulse.
sghioto
Joined Dec 31, 2017
8,751
No. C1 charges up through the npn, R5 and the pnp to V+. Discharges through D1, the internal resistance of the 555 and R5 when powered OFF.
k1ng 1337
Joined Sep 11, 2020
1,038
This circuit triggers a 555 timer on the rising edge of a pulse. The pulse in this simulation is 0-5V with 1ms rise time, 1ms fall time and 100ms on time.
