transistor basics ( as buffer )
electronicsenjoyer089
Joined Feb 24, 2025
182
how so? even without the diode, output of shown circuit still cannot reach negative voltage. transfer characteristic is not changed, all the diode does is protect transistor. in case AC input is applied
It works fine, in case u want ur signal generator to sink that current, also during that phase
panic mode
Joined Oct 10, 2011
5,420
it depends on what one uses as a signal generator. i have FG and tracking PSU that could do +/-30V and 10A. neither transistor not resistor would survive that. so statement "it works fine"only tells me that transistor was not damaged when you applied 9V sine wave from some source (your function generator).
but that is not what i am after - an answer to my question how is transfer characteristic of that circuit affected by adding the diode.
WBahn
Joined Mar 31, 2012
33,314
So... if the input is -5 V, what is the voltage across that diode if the output still cannot reach a negative voltage?
WBahn
Joined Mar 31, 2012
33,314
Here's the circuit with the diode. I've given the source an output resistance of 1 kΩ (R2).
Here's the output of the above circuit. As can clearly be seen, the output (the blue trace) is clearly going negative. With a -9 V input, we would expect the output to be about -4.2 V, which is pretty close (it's actually about -4.12 V in the sim).
