transforming phase slope into delay
yef smith
Joined Aug 2, 2020
1,481
Hello, a single LC cell was made to test delay.the phase increases linearly.how do i find the delay my square wave will get from this slope?
my slope is 1.8 degrees for each 1Mhz.
Thanks.
DickCappels
Joined Aug 21, 2008
10,661
First, have a look at this article;
https://www.rfcafe.com/references/r...-delay-lines-radio-electronics-march-1953.htm
Because of the high harmonic content is rectangular waves, a simple LC delay will distort the waveform significantly. Probably not what you are after, unless you intend to slice the waveform with a comparator. In that case you can adjust the delay by adjusting the threshold
When delaying an analog signal I have had pretty good luck making a simulated transmission line from many LC stages, where the delay of each stage is a small fraction of the waveform being delayed.
Just look under the hood of an old Tektronix scope like the Tek535 and other pretty fast scopes from the 1950’s and 1960’s.
