I must be incredibly dense because I am just not getting it. I know X turns on a primary and X(2) on the secondary is stepping up, and that is about as far as I get. What I am trying to do is step up some electric fencers that have gone bad. Some came out of the package that way and just did not get returned others made it 6 months some 4, I have quite a few of them so I don't need to purchase another I just need to step up their output and be doing something this coming winter. So here is my plans and you guys tell me what ever it is you are going to tell me.
K, each fencer has a ground and a live, it is my live wire that has a tickle for the output. Now I take a pvc pipe and lay down 100 turns glue ends and then paper and lay down 200 turns. Can I paper and lay down a third and a fourth on the same existing lays? If I cant that's ok I can do multiples.
Now what do I do with the coiled wires? Do I loop and solder with a capacitor between them and then affix a lead to another transformer if it is needed?
I know I am using inductance to step up and I know a coil is not a coil unless it is doing work like inducting something else and then on to its work but all the diagrams I look at are not what I am thinking of which I know should be achievable.
I guess what I am describing could be a tesla coil which is fine but all I really want to do is blow up my multimeter so I know I am on the right track, besides I need a new meter anyway and this would be a good reason to go fetch one.
I suppose I could fix the insides but I have already opened a few up and my eyes got crossed up.
