The wire is a stranded wirehi,
Can you see the secondary copper wire, if Yes, then measure the diameter of the copper wire, post what you measure.
Also measure the cross sectional area of the transformers centre laminated limb. post the value.
E
That answers none of Eric's questions.The wire is a stranded wire
Depending on the age of the DVD player, it was probably a ~10W load --it should be written down somewhere on the transformer or the DVD. One can then measure the terminal voltage and the current is simply 10W/voltage measured.I've a transformer from my old DVD player. It's a multiple windings type, I knew this by measuring the voltage at each winding. My problem now is to determine the maximum current from the secondary or probably each winding.
