I am not very good at the maths bit, but I think if the amp is supposed to draw 600 watts at 240v this should work out at 2.5amp.this may be ok.
I was thinking the sameIf you are hitting 2 amps with nothing connected then there is something wrong.
I was getting my reading from the switched outlet socket. This did put the fuse in the circuit I was measuring but I figured it would make the reading go higher if anything. If you think it might change something, I can have a go at that reading tomorrow.Remove fuse F5 mains input to the transformer, and measure the resistance of the transformer primary winding directly at the transformer terminals, what reading do you get?
2.5Amp is correct with full load (max output) if the 600W is rated to operate at 240VAC.I am not very good at the maths bit, but I think if the amp is supposed to draw 600 watts at 240v this should work out at 2.5amp.
If I raise the mains voltage slowly with a variac , I am only putting 120 volts in when I hit 2 amps. This is with all the transformer output fuses removed so none of the PCB's are connected to the PSU.
I could only find the schematic for the US model and it does show the primary as being 125VAC. The one I have is for the UK as it has 240 shown on the back.But drawing clearly shows that this is 120VAC mains...
.I have removed F3, F4, F2 & F1 already and still pulls 2 amps.
No Dolby for me. It is the 2100Which model is it
I have owned the components for a current limit / test box for a few years but never found a reason to build it. Until now, so lunch breaks at work are spent cutting holes in the case to mount the meters and lamps. It should be ready by the weekend.This is where you need a light bulb test circuit while looking for short circuits.
