Transformer Question
Zaraphrax
Joined Mar 21, 2009
49
Hi guys,
I have the following question and I'm a little confused.
The following data for a single phase transformer are given:
No Load Test
Primary Voltage = Vs = 240V @ 0 degrees.
Phi0 = 70 degrees
|I0| = 0.2 A
N1 = 200 turns
N2 = 400 turns
Short Circuit Test Data:
Re = 1 Ohm
Xe = j0.8 Ohms
Ze = 1 + j0.8 ohms (this is referred to primary side).
The secondary side is connected to a load of 20+j36 ohms
Calculate the no-load current I0 and express in polar form. The calculate the primary current I1, supplied under load conditions
Now, the no load current = 0.2 @ 70 degrees (0.2A magnitude, no load power factor angle is 70 degrees)
b) The primary current.
Secondary voltage = 2 * 240 = 480V
Total load impedence = Zl + Ze = 21 + J36.8 ohms
In polar form, this is 42.4 ohms @ 60.2 degrees.
Therefore, the secondary current (referred on the primary side) is:
I'2= 480 @ 0 degrees / 42.3 @ 60.2 degrees = 11.34 A @ -60.2 degrees
From here, I'm not sure which formula I should use. Should I use this:
I1 = I'2 + I'm
Or, I'2 = (N2/N1)I2 to find I2, then use the turns ratio to find I1.
(Hopefully I haven't completely stuffed this up)
Thanks.
t_n_k
Joined Mar 6, 2009
5,455
Firstly, I think you should draw the transformer equivalent circuit to gain a better understanding of what you need to work out. How you draw the equivalent cct will depend to some extent on what you have been taught in class.
You should perhaps try to refer everything - including the secondary load impedance - back to the primary side.
Remember the open circuit test is intended to give you an estimate of the magnetizing impedance (Zm) which shunts the "virtual" primary winding. The short circuit test gives you the series impedance interposed between the actual primary input terminal and the "virtual" primary winding.
When you have all the values worked out you can then calculate the primary current. The impedance seen looking into the primary terminals is
Zp=Zs+Zm||Zs'
Where Zs=1+j0.8, Zm = the primary magnetizing impedance, Zs' = the secondary load impedance referred to the primary.
