Some equipment manufacturers did so routinely - as others stated; the magnetic field could give you a few difficulties.Can I remove the covers from this transformer so that I can mount it flat
from the 4 holes on the core instead of standing up with the feet on it?
Thanks
Enclosure is not tall enough for the transformer to stand up in. I had this one on hand so thought would take the covers off if I could, instead of buying another transformer.Yes, why do you need to remove the covers to bolt it using the transverse holes?
