Transformer keeps blowing fuse.
coinmaster
Joined Dec 24, 2015
502
I bought this transformer https://www.mouser.com/ds/2/410/media-1067263.pdf
I connected the primary in parallel for 115v and the secondary in parallel for 115v but it instantly blows the 6A fuse.
A series connection on the output works fine, but only if it is not connected to anything other than my meter. Even connecting it to a rectifier with nothing connected to its output blows the fuse when wired in series.
I don't know what is happening. I did not miswire it according to the datasheet.
Any advice?
bertus
Joined Apr 5, 2008
23,005
Does the fuse also blow when you leave the secondairy windings open?
It sounds like a misconnection to me.
The colors are clearly given in the datasheet:
Input 1: Series – BLUE and BROWN, Jumper GRAY to VIOLET
Parallel – BLUE and BROWN, Jumper BLUE to VIOLET, GRAY to BROWN
Output1: Series – BLACK and YELLOW, Jumper RED to ORANGE
Parallel – BLACK and YELLOW, Jumper BLACK to ORANGE, RED to YELLOW
Bertus
paulktreg
Joined Jun 2, 2008
851
If the wiring is OK then maybe it's your fuse?
Toriodal transfomers in my experience can pull quite a large current peak on connecting the mains. Are you using a slow blo 'T' type fuse?
strantor
Joined Oct 3, 2010
6,875
I am willing to bet this is exactly the cause. I have also experienced that torroidal transformers have very high inrush current. You need to use very slow fuses with them. Maybe a motor starter would be a good protection device for them.
