You should understand that the formula you mentioned above is only valid if your are matching impedances to the primary winding.The formula that my textbook taught number of windings primary/by number of secondary, square the answer and x the secondary impedance so my answer was coming up 62 ohms. Bounty Hunter, your answer is correct.
E | Impedance in a Transformer | Homework Help | 6 | |
A Wideband impedance transformer/converter. How does it work? | Wireless & RF Design | 4 | ||
S | Help with transformer Impedance | Homework Help | 3 | |
Transformer Impedance Matching Equation | Homework Help | 28 | ||
B | current transformer, high-impedance relay question | Homework Help | 6 |
