Transformer help
Chillum
Joined Nov 13, 2014
546
I need help choosing a transformer, the one that I'm looking at is "Toroidal Transformer, 160VA 0-35/0-35 "
Is that 35v 4.5A?
I have a stepdown circuit with input voltage no bigger that 37V, will this transformer exceed 37v
bertus
Joined Apr 5, 2008
22,997
An 160 VA transformer of dual 35 Volts will have a current rating of about 2.25 A on each 35 Volts output.
bertus
Joined Apr 5, 2008
22,997
No, you can not draw more than 2.25 Ampere on each output.
If you draw more current, you will burn your transformer.
Chillum
Joined Nov 13, 2014
546
how easy is it to build a current limiter? (and the heat question?)
oh and won't lower voltages pull less current then
30,791
It is very easy to modify a toroidal transformer, either by taking turns off, adding turns or simply adding a small secondary if needed.
In the case of the double pair windings, they are usually wound bi-filar which allows removing/reducing both windings at the same time, if needed.
Approx: 2 turns/volt.
ISB123
Joined May 21, 2014
1,236
You can use LM3xx to build current regulator.It will require heatsinks.
After rectification and capacitors you will have 50V at the output.
Chillum
Joined Nov 13, 2014
546
30,791
After rectification and smoothing 30v = 42vdc (30ac x 1.414).
As I mentioned it is comparatively easy to modify a toroidal, I have customized many in the past.
For 37vdc a 26vac is required.
Chillum
Joined Nov 13, 2014
546
I'm wary of adjusting a R600 device. Not only does that power supply exceed my budget by about ZAR200, shipping is going to add another ZAR200-300, so no, not an option
the cheaper one is withing my budget, but probably not after shipping
FOUND IT:
http://www.mantech.co.za/ProductInfo.aspx?Item=372M0368
350 WATT SINGLE OUTPUT ENCLOSED SWITCHING POWER SUPPLY
INPUT: 90-132VAC / 180-264VAC OUTPUT: 36VDC @ 9.7A
30,791
The advantage of a linear supply is it tends to be a alot more rugged and in the event it caves in it can be fixed relatively easily.
This if you do not really need a tight regulated supply.
Chillum
Joined Nov 13, 2014
546
ok , well other than being a switching supply, it's in my price range, it handles high amperage, it's got built in short/overload prrotection, which I can't build because heatsinks (other than cpu heatsinks) doesn't exist in cape town, so unless the switching part is really a problem, this is the power supply for me. your comments/advice please?
