transformer help required
samseed
Joined Feb 11, 2009
4
hello, i have a small transformer which has the specs label missing off the top. can it still be identyfied??.. any help,suggestions greatlly appreciated..cheers....sam
bertus
Joined Apr 5, 2008
22,959
I can only see two wires.
The bottom chamber seems to be empty.
Is there a picture from the other side ?
With only two connections it can be used as a choke.
Greetings,
samseed
Joined Feb 11, 2009
4
I thought it was a transformer.Thanks for clearing that up.yes it only has 2 black wires,and bottom chamber is empty.. Is it just a simple choke or any other name its called by..Meny kind thanks..sam
bertus
Joined Apr 5, 2008
22,959
If you want to know more on transformers take a look at this page of the EDUCIPEDIA.
http://www.educypedia.be/electronics/electricitytransformers.htm
Other components have also pages over there.
Passive semiconductors technology: Batteries Diodes Photovoltaic systems Switches Buzzers Diode types Quartz crystals Thermoelectric Capacitors General overview Relays Transformers Capacitor types Heat Sinks Resistors Transformers-RF Coils Photo diode Resistors-Nonlinear Transformer types
Greetings,
rxtxau
Joined Dec 13, 2003
5
That type of transformer is specially sold in that format in a variety of VA ratings to allow you to wind your own windings onto it. The mains winding is prewound for convenience & to meet electrical safety requirements.
Regards,
Brian.
