Transformer Core Temp vs. Winding Temp
MGPERF
Joined Jun 8, 2021
77
I have a transformer 8 turns primary 240 turns secondary ETD29 core PC44 material running at 30 kHz 14.2 V input I calculated primary turns using the formula/equation (14.2)(10^8)/(4)(30,000)(1800)(5)=1.3 turns primary so I am way over the required number of primary turns however in theory that would prevent the windings from getting hot right? At a steady 4.5 amps the windings get very hot to the point where you can't keep your fingers on them for more than a second or two. Meanwhile the core heats up but significantly less any idea what's going on or how I can solve this problem? I have no air gap currently.
MGPERF
Joined Jun 8, 2021
77
So, this is not a flyback but a forward power supply?
At very low current is the temperature, OK?
It is a lot lower but still hot to the touch.
What is the wire like?
It is 1mm on the primary and .25 mm on the secondary.
Hi Ron,
It is a push pull step up transformer. I just used the calculator below and I am at the absolute limit for bmax given the frequency. I am thinking maybe I can add a turn on the primary? Or maybe a .1mm air gap?
Maximum Flux Density (Bmax) Calculator. (Formulas & Equations) (electricaltechnology.org)
ronsimpson
Joined Oct 7, 2019
4,812
Usually, I can tell if the core or the wire is heating up first.
You want to have about the same loss in each. If the wire heats first, then we need to think about why.
As DickCappels said #18 will probably have skin effect problems. You seem to know your way around the internet. Some where there is a skin effect verses frequency calculator.
28,286
Myguess is that there is also a DC component of the current in the wires that is contributing to the heating. What is this for? Is the idea to have a power supply?
MGPERF
Joined Jun 8, 2021
77
Appreciate all the help! I did some more digging and yes skin effect is a problem at 30 kHz. I am going to switch to an ETD34, add 1 turn to the primary, and run it intermittently using the shutdown pin and Zener diodes once the capacitor is charged to 300 volts rather than running the ETD29 continuously. With the larger core and extra turn I can go to down to 22 kHz safely.
Thanks,
Jon
28,286
If the core is becoming saturated magneticly during any portion of the cycle then there will be much more current and heating and that might be part of the problem. So checking that it is not saturating is a good idea.
If the supply voltage is adjustable, see if reducing the supply voltage a bit drops the output voltage. If not, the core is saturated. So there is a simple and easy test to do. Other folks may have additional tests that may be better.
DickCappels
Joined Aug 21, 2008
10,661
Thanks,
Jon
@MGPERF I could not read the data sheet. What is the benefit of switching from an ETD29 to an ETD34. Is core size the only difference?
28,286
OK, that implies that the core is not saturating, at least that is what I recall from transformer theory class. So the next question is does your application need that much power? If we can presume 90% efficiency, and if you know how much power you need to get from the secondary, you should be able to figure about how much power you need to be delivering to the primary. That might be quite a bit less than you are producing now.
MGPERF
Joined Jun 8, 2021
77
Thanks, my peak requirement is 100 watts of power which is likely a bit much for an ETD29 core running at 30khz. It was getting very hot at 65 watts and that’s all I can test it to with my power supply.
MGPERF
Joined Jun 8, 2021
77
The ETD34 I switched to is rated for 300w according to some sites. I am wondering if that’s at much higher frequencies than the 22kHz I’ll be running. That being said I think it’ll be really reliable at 100w. For core size I always just go with what a catalog recommends etc. then do the math for primary and secondary turns using chosen cores specifications.
