Transformer circuit quistion
TheSpArK505
Joined Sep 25, 2013
126
Hi everyone .
To answer a question u need to understand it 100%...and that's what I'm going for .
I have a question about transformers...and it says:
The transformer secondary is connected to an electrical load , and it delivers its rated current at rated voltage and 0.85 pf lagging , find primary voltage ?
Can any one explain please : what does rated means , and is the power of the load is only due to secondary voltage and as nothing to do with the primary voltage ...and also the underlined part please ??:confused::confused:
Kermit2
Joined Feb 5, 2010
4,159
transformers 'transform' the voltage, current from one side to the other.
The power input = the power output theoretically.
Real world we know there are losses.
The 'power factor' is one of the corrections we apply to determine real world conditions
In the real world power in is ALWAYS more than power out.
Rated levels are given in a piece of equipments specs.
12 V 25 VA transformer(watts)
operates from 110 VAC
So you plug the numerical values found there into your calculations.
TheSpArK505
Joined Sep 25, 2013
126
the question says that a 50 KVA , 2400/240 V, 60 Hz before mentioning any load .....Where does the 50 KVA come from ?
38,929
VA is volt-amps which is just the product of the volts and amps that the transformer is rated for. It is the phasor (phase vector) sum of the real and reactive power.
TheSpArK505
Joined Sep 25, 2013
126
Thanks guts......some of u miss understood me ...my question that there is no load.....where does the 50 KVA come from?
also..does the KVA = Vp,rated*Ip,rated=Vs,rated*Is,rated
38,929
The 50 KVA is the transformer maximum rating. That actual KVA depends upon the load. If there is no load the KVA is essentially zero.
