Multi-tap transformer out of a Sony stereo; model 1-431-655-11,
https://www.manualslib.com/manual/694480/Sony-Hcd-Grx5.html?page=69#manual
http://www.promelec.ru/UPLOAD/xml/scheme/HCD-GRX5_RX66.pdf (page 63)
Known voltages:
65 VAC w CT (approx. 18 gauge wire)
24 & 32 VAC Multi-Tap (approx. 20 gauge)
5 VAC (no taps) (approx. 22 gauge wire)
Looking for specs to tell me what the amperage capability is (or the VA for each section)
Anyone have a suggestion? Or an idea of the amperage based on these (guessed at) wire gauges? (I'm not bad with wire gauge but I wouldn't put money on it). Wire gauge COULD be as big as 16 gauge, but I lack even more confidence saying it's 16 gauge. It probably is closer to 18 gauge. Definitely larger than 20 gauge, but it's been a while since I worked with these gauges. And I can't take a measurement because the wires are encapsulated in epoxy. Just want an idea of how many amps (or watts (VA)) I can expect out of this transformer before I put it on to the parts shelf for later projects.
Couldn't find anything definitive on Google. Maybe someone knows a better source. At best I can get "T11" transformer. There's nothing else on the transformer other than 751022HD and TAM Malaysia UR M 9818
Thanks.
Known voltages:
Thanks.
