Hello all,
Thanks in advance for being here. Last time I gained what I feel is a good basic understanding of cores. Thanks again to DickChappels.
This time I really could use some help getting a better understanding of well... When I see a basic transformer. One primary. One secondary. No tap.
The top coil for lack of a better term is "tuned" to how much force it will put on the secondary. factored by turns and gage of wire. I understand that if I plug in AC power to this coil that someone else made. One that is already correct in its application. the secondary coil will also put out an ac voltage. That voltage will pretty much be as expected based on math. Heres where im almost regressing I feel. What else can I plug in to the primary? DC? I'm getting information pertaining to alternating square waves to drive this older mini-neon lcd Transformer. It is one a lot like this
Pretty sure it was a Great Scott video. He took out the primary. Wound a new one. Four turns. .85 Ga.. Ok well he
did say it was a square wave "inverter" so my guess. His input, no different then simply using a cheap store bought
inverter? Square wave AC. Nothing more. A PWM signal however. Square wave right? Just does not go into the negative
range of voltage yes? If at the point it did dip down into the negative voltage. Would no longer be a DC PWM signal.
At that point you would have Square wave AC. I hope I am right but I dont know? I know I did try to input 12VAC 1 amp
to the four turns I mentioned and when I applied the voltage It seemed nothing happened on the secondary side. Could not
detect voltage. So In my experiment I am aware that my input was not the same as his. However I do not understand why
It would not work or should it? I grabbed the link to the video as well. For anyone that wants to check it out.
