Small problem I am having with a project. I have a vintage aluminum traffic light that I have rewired to a relay board, esp32 and buck converter. My code makes it Alexa controlled and touch sense. The code is not the issue but when I attach the lead from the touch pin to the casing of the chassis, The esp is picking up a constant value of one, whereas when disconnected it is 50. when touched while not connected to chassis it reads about 20.
My question, what would be causing the chassis to read as a touch? How can I fix it, I need to be able to sense touch from the outside casing of the light.
Thank you for any help in advance!
