Tracing a recursive function
zulfi100
Joined Jun 7, 2012
656
I am tracing the following recursive function but i am going into an infinite loop. However when i run the function as a java program its generating an answer. The function is:
static int fun(int i)
boolean res=false;
if(i%2==1)
res=true;
else
res=false;
if ( res )
return (i++);
else
return fun(fun( i - 1 ));
It has to be invoked using:
fun(4):
My steps of tracing are as follows:
fun(4)
= fun(fun(3))
= fun(4)
= fun(fun(3))
= fun(4)
Can somebody please tell me where i am making the mistake??
Zulfi.
RBR1317
Joined Nov 13, 2010
715
While I am not a Java programmer, it does seem a little strange to call a particular function from within that function's own definition.
33,274
This is known as recursion and is a VERY common programming approach to many problems.
A trivial example would be to find the factorial function using recursion:
Code:
int fact(int n)
   if (n < 1)
      return 1;
   return n * fact(n-1);
MrAl
Joined Jun 17, 2014
13,826
boolean res=false;
if(i%2==1)
res=true;
else
res=false;
if ( res )
return (i++);
else
fun(4):
fun(4)
= fun(fun(3))
= fun(4)
= fun(fun(3))
= fun(4)
Zulfi.
What exactly are you trying to accomplish here?
About Recursion...
Yeah, recursive functions are common because sometimes the easiest way is to use recursion. Another example would be when parsing a file system for files and directories. If we call the function for the root directory it can then call itself whenever it encounters a sub directory, and thus gather all the file and directory names. If we did not do it that way we'd have to get all the directories first, creating a 'flat' list, then go through the list one at a time getting all the files. The recursive method is more elegant too. The function has to be written as a reentrant function so that it can hold previous values if needed. Just dont run out of stack space :)
zulfi100
Joined Jun 7, 2012
656
About Recursion...
zulfi100
Joined Jun 7, 2012
656
Thanks WBahn, I am able to solve this problem. Thanks Mr AI for your explanation and a very useful example.
Actually, I am trying to generate the output of recursive function manually. I am calling it Tracing. I saw this method in a book and then i downloaded few recursive methods & tried to apply the method on them. I was able to run only one correctly. Rest were giving me problems. But now things are clear.
Fun(4)
= fun(fun(3))
= fun(3): Note return (3++) would return 3 and not 4
= 3
Zulfi.
33,274
Good, you got it!
What you are doing goes by a number of names. Tracing is one of them. It is also called desk-checking and several others. It's an extremely valuable method both for learning how an algorithm works and also for figuring out why an algorithm doesn't work.
