Okay, so I am working on a way to light a series of lights for my a project I am working on. here is what I am trying to do.
the lights are meant to be attached to circuit that comes on when triggered my something else. While I want this to happen, I want to have the choice to override this and have them be always on.
I am not familiar with a DPST switch, but from what I believe, you can have two power sources and choose between the two with a switch?
For this case I would have the dimmer source which is not always on, and an always on source.
So when I wanted them to be controlled by the thing that will turn them on or off, I could flip to that on the switch, or if I want them to just be on I can flip to the other part of the switch.
Is this how this works?
Is there a better way?
Please help me because I am such an amateur
Okay, in case that didn't make much sense, if you follow this link:
http://www.allaboutcircuits.com/vol_4/chpt_4/1.html
and scroll down to selector switch that is what I am talking about. It can select between two different power sources, and output to the same device( in this case the lights).
