Tone Decoder LM567 not working
prkandel
Joined Sep 3, 2015
8
I bought an IC named LM567 from the market and wanted to use this an a bandpass filter which would give a low output when the input signal to it was 40kHz. In all other conditions and no input signal condition, as per the datasheet states, the output at pin 8 should be a high.
But while connecting the circuit as per the datasheet, the output pin 8 does not give a logic high while there is no input to it. Should not it give a high output as soon as the IC gets the supply Vcc and there is no input to it?
And one more question is that how much input voltage can I give to this IC ? In one equation in the datasheet, I read that the input should not exceed 200mV RMS. However, in maximum input column there was Vcc+0.5 volts. So does this mean that the input can be a 200mV signal riding on Vcc ? Or can I feed pure AC signal with RMS value nearly equal to Vcc ?
Waiting for replies. Thanks in advance.
bertus
Joined Apr 5, 2008
22,925
The output of the LM567 at pin 8 is open collector:
You will need a resistor from the pin 8 to the powersupply to see level changes.
Try a 4K7 resistor for a start.
The given diagram can be found on page 8 of the attached datasheet.
prkandel
Joined Sep 3, 2015
8
Okay, I will try this tomorrow.
But can't I just measure the output from Pin 8 with respect to ground and know whether the output is high or low?
I had read that the output of the decoder is low when the input signal is of the same frequency as the internal oscillator, which indeed is controlled by the resistor between pin 5 and 6 and the capacitor at pin 6. In other situations including when there's no signal, the output should have been high. However, for me, the output is not high when there is no input.
12,131
You are assuming that any output pin can swing both high and low, and this is not correct. Some output pins do not have the ability to produce a positive output voltage. In this case, you complete the output circuit by adding a resistor from the output pin to the positive power supply at pin 4.
ian field
Joined Oct 27, 2012
6,536
AFAICR: the lower the input voltage swing - the sharper the bandpass detection. The Vcc+0.5V should be among the absolute maximum ratings, that is to exceed that limit will likely damage the chip.
prkandel
Joined Sep 3, 2015
8
I will try this too. Well then, if I add a resistor from output pin to power supply, the output at no input will probably be high. Will this also make sure that the output at required frequency be low?
prkandel
Joined Sep 3, 2015
8
I understand this. I just wanted to know if I could provide this chip the input of some 3V RMS(peak to peak voltage 8.48V) while the Vcc is 5V ?
GopherT
Joined Nov 23, 2012
8,009
The datasheet is your friend.
Yes, to your question. The required tone causes the transistor to saturate and output will fall to ground (~0.2V or so).
12,131
Yes, if the resistor value is not too small. The output can sink 30 mA, but there is no reason to drive it that hard. Start with something between 1.0K and 4.7K.
