Hello friends. I am designing a test fixture that will be used for dielectric strength and insulation resistance testing. It will be used for multiple units used on commercial aircraft. My plan is to use 35 toggle switches that will be used to select which wires are in circuit for DS and IR testing. The voltages typically used for these tests will be 1.2KVAC and 500VDC. I've been looking at the S303 SPDT switch from NKK Switches but I'm uncertain as to how their switch voltage ratings will apply in my application. The switches are rated for 15A@125VAC, 6A@250VAC, and 20A@30VDC. As you know, the current in view when doing DS and IR testing is very small, no higher than 5mA.
Will the application of 1.2KVAC and 500VDC from a Hi-Pot tester destroy these switches?
Thanks for your input.
Mike
Mike
