Toggle switch to pulse switch
AnalogKid
Joined Aug 1, 2013
12,253
Yeah, I know. I have a variation that does that, but it still has more passives than yours. I think there was something in the original thread that made me go with unequal pulse widths, but that data has fogged.
ak
AnalogKid
Joined Aug 1, 2013
12,253
Also, separate from your voltage values, two things:
1. The pulse width is only 10 ms, which will not register correctly, if at all, on most meters. You might be able to see an LED blink, but it will be dim.
2. Schematic error. The schematic was originally configured to drive an output transistor that drove whatever downstream. For driving an optocoupler directly as shown, the logic polarity at U1Bpin4 is incorrect. There are several ways to fix this.
One is to add a driver transistor such as the 2N7000 in post #7. Another is to rearrange the output section so the gate drives the optocoupler correctly. A possible issue here is that the standard CD4093 has a fairly weak output stage. This leads to a third option, changing to a 74AC132. This is another quad NAND gate with Schmitt Trigger inputs, but its output stage can source and sink 24 mA. In CMOS-land that's a lot, and way more than what is needed to drive an opto. A minor issue is that the pinout is different from the 4093. I do not know what genius made that call.
Note that if you change the crutschow #7 schematic to use the 74AC132, it also does not need an output transistor to drive an optocoupler.
ak
marcoNLD
Joined Sep 3, 2023
10
ak
I will add a transistor to the output on pin 4. The 10ms pulse should be enough.
So far the 4n35 has proven to be a solution for the initial problem. Even without the second pulse.
i do have another device that needs this circuit so i will continue to try make it work.
So far thank you for your help
