TO-252 and SOT-223 packages
engr_david_ee
Joined Mar 10, 2023
364
The linear regulator LM337 is available in TO-252 (4) package. I would like to use the small package in the schematic and layout. The datasheet is under the link below.
https://www.ti.com/lit/ds/symlink/lm337.pdf?ts=1742459822098&ref_url=https%3A%2F%2Fwww.mouser.de%2F
When I search LM337 on Mouser I found "LM337IMPX/NOPB". The Mouser part number is 926-LM337IMPX/NOPB. But this is available in SOT-223 package. I am wondering if SOT-223 and TO-252 (4) are compatible or not. Any comment ?
LowQCab
Joined Nov 6, 2012
5,102
Have You calculated the expected Heat-Dissipation of the Chip in Watts,
and determined whether your PCB can adequately Dissipate that much Heat ?
