TM1637 LED Drive Control IC
Cmanila
Joined Jan 24, 2017
Anyone here familiar with this IC? This is a multiplexed 7 segment display driver IC that can drive directly common anode small LED display, My circuit is working just fine with small display. I wanted to use this IC to drive a bigger 5 inches common cathode LED display. The large display requires 15 -18 volts DC supply @ 20-40 ma per segment. I tried using optocoupler and transistor pair for the 7 segment drive as well as the common drive but having issues with it. Can anyone share info on how to do this. Thanks in advance.
GopherT
Joined Nov 23, 2012
8,009
Post a schematic of what you tried - it will be easier to have a schematic to work from.
hp1729
Joined Nov 23, 2015
2,304
Segment drive current isn't much different. Digit drive just needs to be increased. Maybe something like thus? There are chips that do such. I don't know what is available currently. Old .. UDN2986 or UDN2985
A datasheet in English would help. I found one in Chinese or Japanese, I can't tell one from the other.
