TL431 spice model contradict the footprint
BobTPH
Joined Jun 5, 2013
11,645
The pin numbers in a schematic do not have anything to do with the pin numbers on a specific package (i.e. footprint.) A device often has multiple package options with different pin numbers. There is usually just one schematic symbol for the device. In my CAD software, I implemented a map that relates the schematic pin names (they are not even numbers, they are text) to package pin numbers.
ericgibbs
Joined Jan 29, 2010
21,567
Hi yef
This is my TL431 file for comparison.
E
* TL431 MACROMODEL ***************3-26-92************************************
* REV N/A ****************************************************************DBB
* REFERENCE
* | ANODE
* | | CATHODE
*.SUBCKT TL431 1 2 3
* Reverse symbol
* Anode Cathode Ref adjusted to LTSPICE symbol
.SUBCKT TL431 2 3 1
V1 6 7 DC 1.4V
I1 2 4 1E-3
R1 1 2 1.2E6
R2 4 2 RMOD 2.495E3
R3 5 7 .2
D1 3 6 DMOD1
D2 2 3 DMOD1
D3 2 7 DMOD2
E1 5 2 POLY(2) (4,2) (1,2) 0 710 -710
.MODEL RMOD RES (TC1=1.4E-5 TC2=-1E-6)
.MODEL DMOD1 D (RS=.3)
.MODEL DMOD2 D (RS=1E-6)
.ENDS
yef smith
Joined Aug 2, 2020
1,479
Hello, Its the same thing, So did i connect the chip correcly ?
So i wont have a surprise when I'll get the PCB.
* REFERENCE
* | ANODE
* | | CATHODE
ericgibbs
Joined Jan 29, 2010
21,567
Hi yef,
The numbers are for model nodes, not IC Body pins.
Re look at this correction.
E
* Reverse symbol
.SUBCKT TL431 2 3 1
38,790
but in the data shhet is another pin order .
So i need to connect the layout as shown below?
Yes.
To reiterate, the Spice model shows a node number, not a pin number.
It is normally unrelated to the actual package pin number, since that can vary between different packages.
eetech00
Joined Jun 8, 2013
4,724
When designing the TL431 footprint for the PCB, ignore the spice model.
Use the schematic and pin orientation shown on the datasheet for the physical package you will use.
