TL431 functionality quesion
yef smith
Joined Aug 2, 2020
1,482
Hello , I have built the following regulator in real life, unfortunetly instead of having on cathode 5V I have 2.78.
R7 is the current limiting resistor and th first thing the I found odd is it has 5V voltage drov over it.
Where did I go wrong connecting the TL431?
Alec_t
Joined Sep 17, 2013
15,158
The junction of R8 and R12 should connect to pin 1. Your PCB traces appear to connect it to pin 2 instead.
Edit: Ignore the above. It applied to the schematic, which has pin numbering different from the physical IC.
