AlbertHall
- Joined Jun 4, 2014
- 12,652
It is very kind of the fakists to make their work so readily identifiable.If the symbol of Texas is upside down then it is a Chinese copy.
https://www.alibaba.com/showroom/lamp-meat.htmlA new Chinese grocery store opened. It was selling LAMP meat because a "b" is a "p" that is upside down. LAMP chops.
I tried 10 mfd and 100nF decoupling capacitor. Problem persists.Hello,
Do you have decoupling capacitors on the boards fitted?
That strongly suggests either a defective opamp or a soldering problem. One can imagine a bad batch of opamps or perhaps more likely damage such as ESD damage when handling the opamps or loading onto a PC assembly.(A lot of text removed for clarity) Once I replace the opamp, then every thing will be fine. This is happening only in some of the boards.
Can you post a schematic complete with all decoupling capacitors?I tried 10 mfd and 100nF decoupling capacitor. Problem persists.
