I am using TL062 opamp in my design. Some of these boards are returning with erratic problem. The problem is , on my table nothing will happen for a day, then suddenly there will be noisy output with offset in output voltage. After few minutes it will return back to normal. There are 4 opamps in the same power supply. But all of them are behaving normally. Once I replace the opamp, then every thing will be fine. This is happening only in some of the boards.
Is this due to high gain in a single stage.
I am attaching the image of my circuit
