TIP 31 A equivalent
The Engineer
Joined Sep 3, 2014
35
I'm am about to print out a PCB in order to build a metal detector , here is the design. http://www.geotech1.com/pages/metdet/projects/twinloop/twinloop.pdf
I am missing a transistor, a TIP31A.
Have looked in a alternative transistor catalogue and have found no results for this component, So I am wondering if anybody on the forum knows of any possible alternatives that will just about to the job ?
Need to hand the detector in in two days so any advice will be very helpful !
Thanks guys.
The Engineer
Joined Sep 3, 2014
35
I have 32C, 34, 41, 120, 121, 126, 127, 3055. And many other transistors available as i'm in college so name any you believe will work !
The Engineer
Joined Sep 3, 2014
35
I do not have time to order unfortunately ! if you could name any you belive will work I will check if they are in the store room
MCU88
Joined Mar 12, 2015
358
Why don't you read the datasheets yourself and see if you have an equivalent. Things to consider with comparison would be:
  • NPN or PNP?
  • hFE / Beta
  • Darlington / super transistor?
  • Bandwidth (MHz)
  • Voltage & current ratings
12,142
TIP41 - yes. 5A instead of 3A, simple substitution.
TIP121 - no. This is a darlington transistor, and might not behave the same as the TIP31 because of the different effective base-emitter voltage.
