Tiny screws- really annoying or absolutely amazing?
What do you think about tiny screws? How, if at all, do they annoy you? You can select multiple ways
  • They are great, and far superior to regular screws!
    Votes: 0 0.0%
  • Total voters
    7
bertus
Joined Apr 5, 2008
23,003
#12
Joined Nov 30, 2010
18,224
I have a set of "security bits" to handle them,
I have one of those kits, but that's only the start. Doing house calls, getting inside all kinds of appliances, and light construction work caused me to accumulate about 400 tips to fit my 1/4 inch socket set. That's the usual 1/4 drive sockets, a couple of security tip kits, a couple of micro-screwdriver kits, and 22 baggies of common and esoteric tips.
I had to bag them! You can't let 400 tips co-mingle in the bottom of a tool box or you'll spend half the day scratching around every time you need to change tips. Besides, what if they started breeding? It would be worse than tribbles.:eek:
ps, Thanks to this Thread, I finally know what those strange Phillips looking tips (that don't seem to fit anything) are called...JIS tips. They look like a Phillips or a Prince Reed, but the flutes are fat.;)
cmartinez
Joined Jan 17, 2007
8,855
Standard Torx screws are star shaped, not hex and do not have a pin in the middle. as shown here:
A version known as Security Torx, Tamper-Resistant Torx (often shortened to Torx TR) or pin-in Torx contains a post in the center of the head that prevents a standard Torx driver (or a straight screwdriver) from being inserted.
Edit: Some time ago I had a device with those security Torx fasteners that I needed to open to repair so I bought a set of the security Torx bits with the hole.
They work on standard Torx fasteners too, of course.
Torx screws are the best type of screws when frequent assembly and disassembly of a mechanism or appliance is needed.
MaxHeadRoom
Joined Jul 18, 2013
30,806
I am really surprised how long it took to replace the slot headed screw!
I really like the Miniature socket set, must be a Chapman.
You can get add-on sets for different head types.
Really useful where a stubby Allen head is needed etc.
Max.
jgessling
Joined Jul 31, 2009
82
Like my portable dishwasher that I seem to be opening up all the time. The sheet metal skin is held on with torx head screws and after I bought a set of drivers it comes off and back on real easy. I have used those drivers on some electronics things too. Happy I have it.
