Here let me elaborate a little more as I didn't in the original question. I'm building a circuit where I'm using the zener diode as a overvoltage protection sorta thing. (Zener is placed so that when the voltage goes past its threshold it shorts to ground). I'm not sure if the diode would conduct normally again after it goes past its "Zener voltage"Uhm.. what? A zener diode does not need to reset, it is not a thyristor or anything like that.It has no memory, and the relation between voltage ad current is just a simple curve.
Imagine a standard diode instead of the zener, just connected backwards so the current can flow. Does it need any kind of resetting?
Nope, not unless the source of the input signals has a high output impedance. As you have shown it, the expectation is that the zener diodes will clamp their signal lines at the zener voltage, but this requires that they sink whatever current is needed in order to make this happen. In general, zener diodes are not intended for high currents (there are exceptions, but they tend to be much more expensive). So if you were just a small amount over the zener voltage with an input signal you might get hundreds of milliamps or perhaps even several amps of current through the diode (and, at that current, the clamping voltage would be elevated quite a bit, too) that will likely destroy the device quickly, usually by letting the magic smoke out resulting it in acting like an open circuit from that point on.Here's a small diagram of my circuit for those who are more visual. I do believe this is how you do overvoltage protection using Zener diodes.
Diagram Link
What you want to use are TVS diodes. Like high power zeners, they have a tolerance that you need to consider.Here's a small diagram of my circuit for those who are more visual. I do believe this is how you do overvoltage protection using Zener diodes.
Is there a way to upload an image directly to a forum post on mobile? I tried using the img tag but it requires a link from an external site. I'll see if I can do it a different way next time, Apologies.
Although a crowbar circuit is probabally the best option for overvoltage, building 3 of those for each line of the power supply is a lot of effort so I may just leave the line unprotected altogether. I appreciate the input everyone gave on me blowing up Zener diodes left and right with my terrible method, but I am still learningThe design is not appropriate for overvoltage protection. What you probably looking for is a crowbar circuit to short the supply when an over-voltage occurs. The circuit you have will likely over-load the zener during over-voltage.
I don't know about from a mobile device specifically, but look at the bottom of the Reply dialog and (on a desktop machine) you will see a link to Upload a File.Is there a way to upload an image directly to a forum post on mobile? I tried using the img tag but it requires a link from an external site. I'll see if I can do it a different way next time, Apologies.
What is the nature of the power source that creates a need for over voltage protection?Although a crowbar circuit is probabally the best option for overvoltage, building 3 of those for each line of the power supply is a lot of effort so I may just leave the line unprotected altogether.
WBahn already explained for you how to upload the file, if you want yo upload the files from cellphone, you should find a compress app for your phone system, before you upload it then you can compress them to a clear resolution as 800x600 or 1024x768 jpg.Is there a way to upload an image directly to a forum post on mobile? I tried using the img tag but it requires a link from an external site. I'll see if I can do it a different way next time, Apologies.
That is misleading to a newcomer. The zener diode does not conduct 0.5V to ground.So (in theory) a 12 volt zener will not conduct to ground unless the incoming voltage exceeds 12 volts. Lets assume your supply is pushing 12.5 volts. The 12 volt zener will conduct 0.5 volts to ground leaving the 12 volts alone.
With what little I know about Zeners,
As I said; "With what little I know about Zener's - - -" . Thanks for teaching me something on this subject. I suspected there would be a need for a resistor, and I hope I didn't take anyone down a road of smoke. Thanks Mr. Chips.That is misleading to a newcomer.
Those tiny common 5V supplies... | General Electronics Chat | 16 | |
| R | VCO stuck with tiny range | Analog & Mixed-Signal Design | 14 | |
ATtiny85 upload on Sparkfun Tiny Programmer 11801 250502 | Microcontrollers | 2 | |
| C | Tiny Tv Circuit Board | Digital Design | 18 | |
| A | Tiny Switchy | General Electronics Chat | 10 |
