Timestep too small
kalemaxon89
Joined Oct 12, 2022
389
I want to simulate the attached circuit but the following error occurs:
Where do I change in the settings the timestep?
I searched but I don't know where it is. I went to the simulation control panel and there are so many parameters: Gmin, Abstol, Reltol etc. does anyone know how to fix it?
Of course, I looked at other posts similar to this one on this forum where they discussed it but I couldn't solve it.
I am attaching the .asc file.
Alec_t
Joined Sep 17, 2013
15,157
Try setting the Edit Simulation Command option to start the external voltages at 0V. You could also try giving your capacitors a finite but small parasitic resistance.
kalemaxon89
Joined Oct 12, 2022
389
I have tried both methods but I have the same problem.
But isn't there an option to change directly the step size? It seems strange to me, I'll look again the LTSpice manual.
38,852
Your circuit can't work.
What's the purpose of C1?
The (+) input of U2 needs to have a resistive (or direction connection) DC bias path to ground, otherwise the op amp will saturate at its rail.
C11 needs a resistor across it to establish the operating DC point, otherwise that will also cause the op amp to saturate at its rail.
R44 serves no useful purpose.
Why is it there?
Bordodynov
Joined May 20, 2015
3,431
Your scheme is totally lousy. There is no DC reference at the input of the second operational amplifier. The operational amplifier model is not complete. I made the circuit read by setting .tran 0 3 0 1m, but got an absurd result. You cannot set a negative voltage less than -0.3V to the input of the operational amplifier. Set the modeling directive I gave. Then see what voltage is at the inverting input of the first amplifier. This voltage cannot be in the real case. I substituted my transistor model and got a completely different result.
You have to make a proper circuit, not modeling garbage! Learn from other people's examples.
I advise you to go to the part of this forum dedicated to schoolchildren and students. There you will be helped to draw a correct scheme.
kalemaxon89
Joined Oct 12, 2022
389
Why is it there?
Sorry, I just realized now that I attached in the main post the screenshot of the previous wrong circuit, now I have updated.
Thank you!
@Bordodynov
kalemaxon89
Joined Oct 12, 2022
389
Your updated schematic has error 404 Could Not be Found
Your original schematic is very confusing and has some errors.
I tried to re-upload both the schematic and the screenshot in the main post.
The initial photo you are talking about (which you attached in your reply) is the wrong one, I had uploaded the wrong photo but due to my distraction
