I am building the attached circuit to turn on a motor for 60 seconds, then turn off for between 2 minutes and 5 minutes, and then repeat. A PIC12F675 is used and the variable delay is achieved by adjusting the 10K pot and the A/D conversion of the PIC.
I am testing the attached circuit on my bench using a 12VDC electric drill as the motor. The drill is drawing ~4amps. When the design is finalized, I would like the circuit to power a motor up to 10amps.
The PIC and its software, along with components associated with the PIC work fine. I have build a few circuits using a PIC to drive a relay and haven't had any problem.
This is my first attempt using a MOSFET. I am using a IRF540 and have attached an aluminum heatsink (removed from my old stereo).
I tried turning on the MOSFET using the 5V from the PIC but didn't have any luck. I used an OPTO I had laying around and got the motor to turn on, but after a short time (20 seconds) the MOSFET/heat sink got very hot. Too hot to touch. I ran the PIC program for one or two cycles and decided to shut it down before something melted.
I need some advice/help on using this MOSFET to turn on the motor but configuring it in such a fashion as not to over heat it. Any suggestions would be appreciated on how to keep avoid this over heating down or other circuit suggestions.
Thank you.
JG
Thank you.
JG
