Time Step to Small LTSpice for Gate Drive
kalemaxon89
Joined Oct 12, 2022
389
I would like to simulate the switching of this gate drive.
I am not very familiar with the operation of the bootstrap circuit etc. but I would like to do just a couple of simulations at least to verify that the SW output is consistent with what is stated in the datasheet (look to the right in the schematic image the "table" taken from the datasheet).
The problem is the too small timestep on node nn3 (i.e. HS pin)
I have tried varying/removing each individual component but the problem persists.
I have also tried varying these parameters, but it does not work:
I have attached the simulation and the library from which I auto-generated the gate driver.
kalemaxon89
Joined Oct 12, 2022
389
Hi k89,
Please post the LMG model file.
E
I don't know what the LMG file is and where it is, but I have lmg5200.lib inside LTSpice and I generated the component from from ".subckt LMG5200_TRANS HB HI HS LI PGND AGND VCC VIN SW params: del_match=2n"
Where is the LMG file located?
kalemaxon89
Joined Oct 12, 2022
389
hi k,
Try this, note the .options
E
hi @kalemaxon89
E
It works! Thank you so much for your help
I just found all those options in the ltspice help.
Basically:
- increased cshunt (capacitance) from 0. to 10f
- increased gshunt (conductance) from 0. to 1n
- increased abstol (tolerance) from 1pA to 1n
- increased vntol (tolerance) from 1u to 1m
- nomarch: don't plot marching waveform .. what does it mean?
ericgibbs
Joined Jan 29, 2010
21,597
Hi @kalemaxon89
The easy way to show the effect of no march.
Change the .tran to say 200uSec, run the sim, note the waveform plot is slightly delayed, but when it appears it will be the complete waveform from 0uS to 200uS.
Delete the no march word from the options list.
Run the sim, you will see the plot waveform being generated slowly step by step from 0uS to 200uSec
The sim will take a little longer to run.
E
kalemaxon89
Joined Oct 12, 2022
389
Hi @kalemaxon89
E
Thanks!
However, I do not understand why this "disturbance" on feeding occurs:
I varied the output (using L and R as a motor load)
