Hi everyone.
I need to build a Trigger that will be switched on for a period of time that may be shorter than the length of the input pulse.
I tried to build this with a RC time constraint but I have a problem discharging the cap once the input signal disappears. Also if the Input signal is shorter that the time I want the switch on my plan is doomed (but I do not think this should be the case). I also tried a 555 timer in a mono stable state but that only add the time delay to the time that the input signal is switched on.
It is possible for me to change the design to Start my trigger when the Pulse is absent like in the second part of the image.
I hope this is clear enough. But a picture is worth a thousand words so please look at the attached picture. Like I said the second pulse should not happen. Also the actual length of the output pulse must be adjustable with a variable resistor.
Please help me to get this done. Thank you very mush.
