I have an assignment that consists in the creation of a full-adder using the microcontroller unit listed in the title. I understand the logic of the gates and how this all would work out operation-wise
What I am stuck on is if there is a necessity to use CMOSes to create each of the given logic gates as seen in the diagram below. What I have so far is the MCU which I believe should send out the three inputs, a couple of LEDs (to demonstrate the output (1 being on, 0 being off) and I don't know what else would be required in this case.
I can create the code but I need a little guidance as to how to start programming this and getting the desired results.
Thank you in advance.
