TI-36X Pro Calculator Problem
SamR
Joined Mar 19, 2019
5,539
It's what I use mostly for solving problems along with Microsoft Mathematics on my computer and also have the TI-nspire CXII CAS calculator. Here is the problem...
But how can I get the TI-36 calculator to do it? I've tried using its Numeric equation solver but got an Invalid Domain Error so I'm not doing it correctly?
Edited to remove ambiguity
WBahn
Joined Mar 31, 2012
33,255
I'm not familiar with the notation you are using.
When you say
solve( a = f(x,y), a)
What, exactly does that mean? What is it that you are solving for?
SamR
Joined Mar 19, 2019
5,539
Here is the initial expression in MS Mathematics
Which it then translates to
Which it then solves as
Right back where we started! What I am trying to get it to resolve to is
Which MS Mathematics then solves as
I guess what I am looking for is the complex form of the simplified equation? Instead, it wants to simplify the simplified equation which it cannot do since it is already in the simplified form. The TI-36 has some solving abilities but it gives me an Invalid Domain Error. So, I was hoping someone had an answer as to how to get the complex form on the TI-36. Sometimes learning how to use the machine to save time takes longer than just doing it by hand!
WBahn
Joined Mar 31, 2012
33,255
I'm still unclear as to what it is that you are looking for.
How does a = (y+2x)/(xy) constitute any more of a solution to anything than a = 1/x + 2/y does?
Given the variables and the general form of the equation, this looks like the equations for a curve in the xy-plane given some parameter 'a'.
For instance, if we had a = x^2 + y^2, this would describe a circle having a radius of sqrt(a).
Looking at what you are given:
a = 1/x + 2/y
We see that neither x nor y can be zero.
We also see that if x = 1/a that y must be infinite and, similarly, if y = 2/a that x must be infinite.
So we have two asymptotes, a vertical one at x = 1/a and a horizontal one at y = 2/a.
We can then solve for y(x) and get
y = 2x/(ax-1)
If we plot this, we get the following for a = 5.
The vertical line at x = 1/a = 0.2 is an artifact of how the plot was generated. That should be a dashed line indicating the vertical asymptote. Furthermore, there should be a circle at the origin since the original function is not defined there.
Does any of that help you at all?
SamR
Joined Mar 19, 2019
5,539
Not really. I'm not interested in plotting it and yes, MS Mathematics can do that. What I was looking for is, using the TI-36, MS Mathematics, or TI-nspire, how do I (if possible) use them to translate
into a single expression of
I'm sorta going backwards from simplified expression to complex expression which is the antithesis of what the calculators normally do and not covered in their documentation that I can find.
38,857
I doubt you will find any program to do that since, as you say, it's going backwards.
So why do you want to go backwards?
It's sort of like uncooking an egg.
SamR
Joined Mar 19, 2019
5,539
Yup, it is. It was a problem that I was given to solve with the calculator in a John Bird book "Electrical Circuit Theory and Technology". Unless someone knows a trick, I agree, I don't think it can be. I've spent far too much time trying to do that with the calculator, reading manuals, and researching to find a method when it is a very simple expression to resolve manually on a scratch pad and in my head.
